[FIXED] Contact Sync hangs on "Batch storing contacts..."
- Has thanked: 4 times
- Been thanked: 15 times
EssentialPIM Pro 5.57 Network; Windows 7 Prof 64bit
EssentialPim Android free 3.0.2; Android 4.3.1 (CyanogenMod 10.2.1), Samsung Galaxy S4 Mini (GT-I9195, serranoltexx)
EssentialPim Android free 3.0.2; Android 4.1.2, Samsung Galaxy Note 10.1 (GT-N8000)
- Normally daily sync with GT-I9195 (no problems)
- Today sync with GT-N8000 failed with contact sync hanging on "Batch storing contacts..."
- Following attempt to sync with GT-I9195 hangs on "Batch storing contacts...", too.
Sync settings (to minimize side effects, keep log simple, etc.):
- Sync only contacts
- 1-way sync Epim -> Android
- Synchronize deletions
Cleared synchronization data before sync.
Symptom: contact sync hangs on "Batch storing contacts..." (see end of log).
Log Ends with "Batch storing contacts...".
Task manually stopped at 10:40
Calender, Notes, ToDo, and Password sync flawlessly
Any suggestions?
Nurgotora
Code: Select all
2014.03.13 10:24:50.154 EssentialPIM Pro 5.57 14.09.2013 14:03
2014.03.13 10:24:50.159 Server started at port 21114
2014.03.13 10:24:50.160 Local IP address(es):
2014.03.13 10:24:50.160 EssentialPIM Pro 5.57 14.09.2013 14:03
2014.03.13 10:24:50.160 192.168.0.101
2014.03.13 10:24:50.160 192.168.88.1
2014.03.13 10:24:50.161 192.168.153.1
2014.03.13 10:24:50.161 Server started at port 21115
2014.03.13 10:24:50.161 169.254.15.187
2014.03.13 10:24:50.161 Local IP address(es):
2014.03.13 10:24:50.162 192.168.0.101
2014.03.13 10:24:50.162 192.168.88.1
2014.03.13 10:24:50.162 192.168.153.1
2014.03.13 10:24:50.162 169.254.15.187
2014.03.13 10:24:50.163 EssentialPIM Pro 5.57 14.09.2013 14:03
2014.03.13 10:24:50.164 Server started at port 21116
2014.03.13 10:24:50.164 Local IP address(es):
2014.03.13 10:24:50.164 192.168.0.101
2014.03.13 10:24:50.164 192.168.88.1
2014.03.13 10:24:50.165 192.168.153.1
2014.03.13 10:24:50.165 169.254.15.187
2014.03.13 10:24:50.177 Announced by multicast.
2014.03.13 10:24:50.179 Announced by multicast.
2014.03.13 10:25:03.200 Client 192.168.1.50 connected
2014.03.13 10:25:03.202 Received message from client
2014.03.13 10:25:03.202 InfoReceived
2014.03.13 10:25:03.306 Requesting contacts...
2014.03.13 10:25:03.306 XML Parsed
2014.03.13 10:25:03.323 Received message from client
2014.03.13 10:25:03.323 XML Parsed
2014.03.13 10:25:03.324 Requesting data...
2014.03.13 10:25:04.554 Received message from client
2014.03.13 10:25:04.562 XML Parsed
2014.03.13 10:25:04.562 Requesting data...
2014.03.13 10:25:06.136 Received message from client
2014.03.13 10:25:06.143 XML Parsed
2014.03.13 10:25:06.143 Requesting data...
2014.03.13 10:25:07.370 Received message from client
2014.03.13 10:25:07.378 XML Parsed
2014.03.13 10:25:07.378 Requesting data...
2014.03.13 10:25:08.424 Received message from client
2014.03.13 10:25:08.433 XML Parsed
2014.03.13 10:25:08.433 Requesting data...
2014.03.13 10:25:09.612 Received message from client
2014.03.13 10:25:09.621 XML Parsed
2014.03.13 10:25:09.621 Requesting data...
2014.03.13 10:25:10.691 Received message from client
2014.03.13 10:25:10.700 XML Parsed
2014.03.13 10:25:10.700 Requesting data...
2014.03.13 10:25:11.656 Received message from client
2014.03.13 10:25:11.665 XML Parsed
2014.03.13 10:25:11.666 Requesting data...
2014.03.13 10:25:12.845 Received message from client
2014.03.13 10:25:12.855 XML Parsed
2014.03.13 10:25:12.856 Requesting data...
2014.03.13 10:25:13.929 Received message from client
2014.03.13 10:25:13.939 XML Parsed
2014.03.13 10:25:13.939 Requesting data...
2014.03.13 10:25:15.137 Received message from client
2014.03.13 10:25:15.148 XML Parsed
2014.03.13 10:25:15.148 Requesting data...
2014.03.13 10:25:16.192 Received message from client
2014.03.13 10:25:16.203 XML Parsed
2014.03.13 10:25:16.203 Requesting data...
2014.03.13 10:25:17.389 Received message from client
2014.03.13 10:25:17.401 XML Parsed
2014.03.13 10:25:17.401 Requesting data...
2014.03.13 10:25:18.536 Received message from client
2014.03.13 10:25:18.546 XML Parsed
2014.03.13 10:25:18.547 Requesting data...
2014.03.13 10:25:18.818 Received message from client
2014.03.13 10:25:18.820 XML Parsed
2014.03.13 10:25:18.825 ContactsSync
2014.03.13 10:25:18.836 ContactsCount=663
2014.03.13 10:25:18.837 ContSyncInfoCount=0
2014.03.13 10:25:18.911 AnSContactsCount=658
2014.03.13 10:25:18.913 NewItems.Count 663
2014.03.13 10:25:18.913 Add1 673 21700610247752682
2014.03.13 10:25:18.913 Add1 674 9571571366070425
2014.03.13 10:25:18.913 Add1 675 61276158359639032
2014.03.13 10:25:18.913 Add1 676 25662364427951221
[... similiar entries "Add1" for 677 through 1333 omitted ...]
2014.03.13 10:25:18.996 Add1 1334 16356401934890158
2014.03.13 10:25:18.996 Add1 1335 9984073018899783
2014.03.13 10:25:18.996 NewItems.Count 5
2014.03.13 10:25:18.996 Add3 11716502490707966
2014.03.13 10:25:18.997 Add3 68747611011646536
2014.03.13 10:25:18.998 Add3 15964923162606498
2014.03.13 10:25:18.998 Add3 7839236611840061
2014.03.13 10:25:18.999 Add3 40783385889441954
2014.03.13 10:25:18.999 ContactsStore
2014.03.13 10:25:19.063 ContactsSync OK
2014.03.13 10:25:19.063 AnSContactsStore
2014.03.13 10:25:19.085 Batch storing contacts...
Any suggestions?
Nurgotora
- Been thanked: 1134 times
Re: Contact Sync hangs on "Batch storing contacts..."
Thank you, will try to fix in the next update. Meanwhile please temporarily exclude contacts from the synchronization.
Update:
- Reverted to yesterdays backup
- Contact Sync with GT-I9195 works flawlessly
- Contact Sync with GT-N8000 hangs (since 17 Minutes) at "Batch storing contacts..."
Extensive Logging reveals[... private data, available on request ...]
End of log
Code: Select all
2014.03.13 12:21:26.585 Batch storing contacts...
2014.03.13 12:21:26.585 <?xml version="1.0"?>
<command>
<type>3</type>
<id>0</id>
<contacts>
<contact><opNum>1</opNum>
Code: Select all
<operation>2</operation>
<id>106</id>
<contactId>106</contactId>
</contact>
</contacts>
</command>
Happens the same to me, and the log is the same.
The synch settings is "both directions" and includes everything but passwords...
Essential PimPRO Portable v5.57 in Spanish, Windows 7 Pro x64 English
EssentialPIM for Android FREE, Android 4.0.2
Thanks, working on it!
Same problem here. Win7 32-bit; using Portable Pro 557. Worked fine last week before the latest android app version, Is there a way to retrieve the previous android app version? If not, can you post the .apk for the previous app version on this site? Thanks!
Your wish is our command. 2.5.4 version is attached to this post. The new 3.0.3 version with this issue fixed is on its way, though. Need couple of more days for testing.
- EssentialPIM.apk
- (4.33 MiB) Downloaded 325 times
Guys, here's preview of the 3.0.3 version that should have the problem with synchronization of contacts fixed. Could you please try it out and confirm? Thanks in advance!
- EssentialPIM.apk
- (5.16 MiB) Downloaded 272 times
Sorry, but same symptoms:admin wrote:Guys, here's preview of the 3.0.3 version that should have the problem with synchronization of contacts fixed. Could you please try it out and confirm? Thanks in advance!
- EssentialPim Android free preview 3.0.3; Android 4.1.2, Samsung Galaxy Note 10.1 (GT-N8000)
- hangs at "Batch storing contacts..." (stopped task manually after 34 Minutes):
Code: Select all
2014.03.19 12:26:23.197 Batch storing contacts...
2014.03.19 13:00:51.999 Server stopped
- After success with 2.5.4, tested again with 3.0.3, same symptom: hangs at "Batch storing contacts..."
PS: On the Tablet, since 3.0.2 the sync screen insists on being in portrait mode, all others insist on being in landscape mode... puts a strain on my neck while testing.
To "admin"... Please
a) treat us with some care. I do not consider myself a "guy for testing", but a current customer of Astonsoft.
b) provide us some more confidence, rather than, "here it is, please test this version".
I am assuming that this is a quick way to find bugs and fix them, but a more formal support process might have to be taken... Were you able to reproduce the problem? Do you need any extra info to reduce the scope? Will you please share with us (at least, the customers with paid licenses) the source of the problem (communication, network management, character enconding parsing, whatever)?
Will the next release have in the What's new notes "Some minor fixes"?
thank you.
Until it has been proven, I will stick to the previous version. And I have no plans to buy the PRO version for Android, of course...
EssentialPIM PRO, lifetime license, 5.57. EPim4Android v2.5.4 in Android 4.0.4, lenovo A390, Spanish Windows 7x64 with Spanish data.
thank you.
mlin, please don't pay attention to the intermediate versions. If you wish to be sure the issue is fixed, wait till the official release on the Google Play Store. Thanks!
People who wish to test yet another update, please download it from this post. You might also notice performance improvements with the Month widget
Would appreciate your feedback, thanks!
- EssentialPIM.apk
- (5.16 MiB) Downloaded 392 times
Max,
No luck with the month widget. It still stalls my phone to a crawl.
Switching between home pages takes 2 or 3 seconds.
Bill
KB5CTH
Droid Razr running Android Version 4.1.2
EPIM 3.0.3
The version I loaded from your website says it is version 3.0.3. Isn't that the same as the previous version? Perhaps these test programs should be numbered so we know which version (test or real) we're running.admin wrote:You might also notice performance improvements with the Month widgetWould appreciate your feedback, thanks!
Bill
KB5CTH
EPIM 3.0.3
