Email: RCPT ERROR MESSAGE
All of sudden I am receiving the following error: Need RCPT before DATA
Re: Email: RCPT ERROR MESSAGE
did the problem start after update to 5.8? If yes, please see following:
viewtopic.php?f=2&t=15099
I updated to 5.8 a while ago and didn't have an issue until just a few days ago. Based on the reference you sent regarding deleting the dll files and replacing them with the updated files, I am still having the same issue with the same error message. Also, I was prompted to update to 5.81, so I updated the application as well in hopes that it would solve the problem. Unfortunately, I still have the same error message.
To provide more information for a resolution, attached is another screen shot of the error message and the mail logs. Looking forward to a resolution.
Rochelle
Rochelle
- 2014-05-15_1105.pdf
- (9.91 KiB) Downloaded 274 times
error_2014_05_14_13_56_11.log
- (3.03 KiB) Downloaded 263 times
error_2014_05_14_13_29_21.log
- (2.98 KiB) Downloaded 245 times
error_2014_05_14_13_29_16.log
- (2.88 KiB) Downloaded 260 times
Thank you. Unfortunately what you attached are not mail logs.
Best for us is to get the credentials for your mail account to check ourselves, OR, test account on the same server.
Attached are my credentials for my email. Also, if we can’t resolve this issue.. how I can roll back the version because I tried a back up from a month ago and I was able to retrieve my email perfectly, so this is certainly an updated version issue.
First of all, please immediately change your password for the email account. You should have sent your password in private message.
I have just checked with the following settings in EPIM it works fine:
I was worried about the password issue. However, I'm confused because the information I sent was for a Pop setup and not a IMAP setup. I can't use the pop set up?
IMAP is much better actually in most cases, so I would suggest to use that.
I tried imap and it works but I really don't want imap for my desktop. Can you tell me how to roll back the version. The previous version worked perfectly.
