Recurring Event
wrbird
Recurring Event
Post by wrbird »
How due you make a recurring event, such as Labor Day?
Has thanked: 1616 times
Been thanked: 1134 times
Re: Recurring Event
Does it have a specific recurrence pattern?
wrbird
Re: Recurring Event
Post by wrbird »
Yes, the first Monday of September. There's also others, i.e., the third Thursday of November
wrbird
Re: Recurring Event
Post by wrbird »
The desktop version allows for these type of recurring events. Just make the android version the same.
Re: Recurring Event
Yes, we plan to. Meanwhile you can create these type of events in Windows EPIM and then sync with Android EPIM. The appointments should be able to recur correctly on Android even though you cannot create such a pattern in Android EPIM Calendar, yet.
