Improvement in To Do
chg
Post by chg »
I have a suggestion to improve the To Do module: the filters options that were chosen could be automatically saved, so every time I start EPIM it would not be necessary to set the desired filters again. Even better, could there be an option to turn on or off such feature.
Regards,
Christhiaan
Re: Improvement in To Do
Thank you, suggestion noted.
Efkan.Sarikaya
Post by Efkan.Sarikaya »
It will be good to create a To Do and assign it to Notes or create a To Do in Notes .
NormTheStorm
Been thanked: 63 times
Post by NormTheStorm »
Hello Efkan,
Have you ever considered using an hyperlink pointing to your required EPIM item ?
Capture item link.JPG (9.92 KiB) Viewed 2196 times
Works great !
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.5737) 64-bit, 8 GB RAM, EPIM Pro Life 12.2 (Build 1034)
