Related item does not appear
Using EPIM Pro 6.55 under Windows 7 Professional 64 bit.
I have a contact that I have linked to various ToDos and calendar items. The same method was used to link these items. I right click the contact, copy the link and insert it into the subject line of the ToDo or calendar. All of the links show in this contact's related item tab except for one. The only thing unique to this non-showing calendar entry is that it is a future appointment. The others are all in the past.
I don't think I did anything wrong the would prevent this entry from displaying. As I said, it was created the same way as the others. I am especially concerned because I rely on the related items tab for accurate information.
By the way, I have tried database optimization to no avail.
Thank you for any advice you can provide.
Jon
EDIT: I found the problem. The missing item is there but not displaying as I would expect. I see that the related items display their creation date - is this correct? This is not very useful for me because I would like to scan for the due date (ToDo) or date of the appointment. Even better would be a way to configure the related items view with sortable columns. Is this possible?
Jon
Re: Related item does not appear
currently this is not possible, but thank you for the suggestion. If there will be more requests for this- we will consider implementing.
Hi Max. Please see the first post here viewtopic.php?f=3&t=16524&p=71838&hilit ... mns#p71838.
