Tabla en Android
asantarelli
Tabla en Android
Post by asantarelli »
Hola...
en la aplicación para Windows, en una nota, inserté una tabla (un horario escolar).
Cuando sincronizo con Android, en la aplicación de Android, el formato de la tabla se pierde.
Se ve como texto plano, muy mal organizado.
Que esta pasando? Es un error? o no se soportan las tablas?
Muchas gracias..
Saludos...
Has thanked: 1639 times
Been thanked: 1160 times
Re: Tabla en Android
Unfortunately tables aren't supported in Android EPIM just yet. Thanks!
asantarelli
And will be added in future versions?
I think it is a very interesting feature in the Windows version, and for compatibility issues, it should be supported ...
I add notes with tables in the PC version. After syncing twice, the notes in the PC version looked like in the Android (deleted table structure ..) That should be improved.
Yes, we're looking to implement this feature in one of the upcoming versions of the app.
