Problem after Update on 7.52
hepcat
Post by hepcat »
After restarting the update to version 7.52 (Business Edition, 3 Clients) I get the following warning (see picture) :( Image
Even after changing the backup folder, a backup is not possible.
It is very urgent as we use Epim in the office
Best Regards
Olaf
- HepCat -
Texter
Has thanked: 21 times
Been thanked: 184 times
Re: Problem after Update on 7.52
Post by Texter »
In der Netzwerkversion habe ich diesen Fehler ebenfalls.
Im Hilfetext steht, dass man auf die automatische Funktion der Sicherung verzichten soll.
Stattdessen soll man ein anderes Tool verwenden um Datenbanken automatisch zu sichern.
Derzeit habe ich die Autobackup-Funktion deaktiviert.
*including RC`s
the first start of upgraded Network version should be done on server, using File-> Open to locally open the database so that it could be properly updated. So, start EPIM on server and use File-> Open.
Also make sure you have plenty of space for backup and database convertation. You should have at least 3x database size free space.
