EPIM ANDROID BUG: Sorting task lists
Has thanked: 794 times
Been thanked: 426 times
Re: EPIM ANDROID BUG: Sorting task lists
Yes, there's the Pro version of Android EPIM. You can tap on Menu->Settings->About and check if it says EssenitalPIM with a "Pro". If yes, you have the Pro version.
I can confirm that synchronization of manual sort order for tasks is not yet working as it should but this will be addressed in the next update.
Will think about preserving the manual sort order for the Windows version of EPIM, thanks for bringing this up.
Jeff K
Post by Jeff K »
Thank you!
I've now upgraded to Android Pro 5.7 Beta 3.
I'm looking forward to your next Windows update!
Synchronization of manual sorting order should be fixed on the Android's side. So this is going to be included in the Android EPIM version update :)
