How To Change the Database Password
Nurgotora
Has thanked: 4 times
Been thanked: 15 times
Post by Nurgotora »
Answer:
1. Connect to database as SYSDBA
2. Choose Menu Tools => Users
Original Post:
I'd like to change the database password both for SYSDBA and the user.
Help, a forum post from 2013, and zendesk, 2015 say:
Q: I have created a password, but how can I change my password?
A: You need to go to File -> Password protection, erase asterisks and enter your new password.
But there is no (menu)File -> (Item)Password protection in EssentialPim Windows 7.63 - or am I blind?
Cheers,
Nurgotora
Re: How To Change the Database Password
to change passwords for Business version, please use Tools-> Users menu.
Nurgotora
Post by Nurgotora »
Mhmmm,
There's no such thing as "Users".
I've bought (years ago) and always updated with EssentialPIMProNetX.exe
the menu appears when you you open the database using EPIM server (File-> Connect to Server). If you have opened database directly from disk, using File-> Open menu, the menu won't appear.
Nurgotora
Post by Nurgotora »
That's exactly what I always do (File-> Connect to Server) and it wouldn't show...
... because I connect as the normal user.
Thinking, I tested how it would look if I connect as SYSDBA, and ta-daa!, "Tools-> Users" is there.
"Tools-> Users" is only available when connected as SYSDBA
Ah-ha.
