CalDav sync with Radicale: No categories
EssentialKURT
Post by EssentialKURT »
Hello
When syncing my Epom calendar to Radicale (2.1.9) the categories are not exported. Why is that not transmitted?
Here is the log of a test sync with one entry:
Code: Select all
EssentialPIM Pro 8.0  28.06.2018 18:23
23:03:19.286  5056  Start Sync 192.168.1.60:5232  1427975132
23:03:19.289  5056  SyncTasks
23:03:21.711  5056  PROPFIND /fhem/1fbbed90-cbe6-5429-7d7e-92fe942f48be/ HTTP/1.1<EOL>Content-Type: application/xml; charset=utf-8<EOL>Content-Length: 191<EOL>Depth: 1<EOL>Host: 192.168.1.60:5232<EOL>Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8<EOL>Accept-Encoding: identity<EOL>User-Agent: Mozilla/5.0<EOL><EOL>
23:03:21.711  5056  <?xml version="1.0" encoding="UTF-8"?><EOL><D:propfind xmlns:D="DAV:" xmlns:C="urn:ietf:params:xml:ns:caldav"><EOL>  <D:prop><EOL>    <D:getetag/><EOL>    <D:getlastmodified/><EOL>  </D:prop><EOL></D:propfind>
23:03:21.715  5056  HTTP/1.0 401 Unauthorized<EOL>Date: Thu, 02 Aug 2018 21:03:20 GMT<EOL>Server: WSGIServer/0.2 CPython/3.5.3<EOL>WWW-Authenticate: Basic realm="Radicale - Password Required"<EOL>Content-Type: text/plain; charset=utf-8<EOL>Content-Length: 43<EOL><EOL>Access to the requested resource forbidden.
23:03:21.846  5056  PROPFIND /fhem/1fbbed90-cbe6-5429-7d7e-92fe942f48be/ HTTP/1.1<EOL>Content-Type: application/xml; charset=utf-8<EOL>Content-Length: 191<EOL>Depth: 1<EOL>Host: 192.168.1.60:5232<EOL>Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8<EOL>Accept-Encoding: identity<EOL>User-Agent: Mozilla/5.0<EOL>Authorization: Basic ZmhlbTpmaGVtdXNlcg==<EOL><EOL>
23:03:21.847  5056  <?xml version="1.0" encoding="UTF-8"?><EOL><D:propfind xmlns:D="DAV:" xmlns:C="urn:ietf:params:xml:ns:caldav"><EOL>  <D:prop><EOL>    <D:getetag/><EOL>    <D:getlastmodified/><EOL>  </D:prop><EOL></D:propfind>
23:03:21.877  5056  HTTP/1.0 207 Multi-Status<EOL>Date: Thu, 02 Aug 2018 21:03:20 GMT<EOL>Server: WSGIServer/0.2 CPython/3.5.3<EOL>DAV: 1, 2, 3, calendar-access, addressbook, extended-mkcol<EOL>Content-Length: 339<EOL>Content-Type: text/xml; charset=utf-8<EOL><EOL><?xml version='1.0' encoding='utf-8'?><LF><multistatus xmlns="DAV:"><response><href>/fhem/1fbbed90-cbe6-5429-7d7e-92fe942f48be/</href><propstat><prop><getetag>"737052512bacd8310cd0384474e7fe68"</getetag><getlastmodified>Thu, 02 Aug 2018 21:02:14 GMT</getlastmodified></prop><status>HTTP/1.1 200 OK</status></propstat></response></multistatus>
23:03:21.880  5056  SyncInfoCount=0
23:03:21.887  5056  TasksCount=1
23:03:21.887  5056  EventCount=0
23:03:21.887  5056  NewItemsCount=1
23:03:21.887  5056  CopyTask6 20180802T2303211660435471  243524629149793580
23:03:22.022  5056  PUT /fhem/1fbbed90-cbe6-5429-7d7e-92fe942f48be/20180802T2303211660435471.ics HTTP/1.1<EOL>Content-Type: text/calendar; charset=UTF-8<EOL>Content-Length: 287<EOL>If-None-Match:*<EOL>Host: 192.168.1.60:5232<EOL>Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8<EOL>Accept-Encoding: identity<EOL>User-Agent: Mozilla/5.0<EOL>Authorization: Basic ZmhlbTpmaGVtdXNlcg==<EOL><EOL>
23:03:22.023  5056  BEGIN:VCALENDAR<EOL>VERSION:2.0<EOL>PRODID:-//Astonsoft//EssentialPIM//EN<EOL>CALSCALE:GREGORIAN<EOL>BEGIN:VEVENT<EOL>LOCATION:Zu Hause<EOL>SUMMARY:Testeintrag<EOL>DTEND:20180803T183000<EOL>DTSTART:20180803T180000<EOL>DTSTAMP:20180802T210321Z<EOL>UID:20180802T2303211660435471<EOL>SEQUENCE:1<EOL>END:VEVENT<EOL>END:VCALENDAR<EOL>
23:03:22.741  5056  HTTP/1.0 201 Created<EOL>Date: Thu, 02 Aug 2018 21:03:21 GMT<EOL>Server: WSGIServer/0.2 CPython/3.5.3<EOL>ETag: "8fc416110144358d008c4c345fa8e32c"<EOL>Content-Length: 0<EOL><EOL>
23:03:22.745  5056  SyncTasks OK
23:03:22.745  5056  Sync OK
Re: CalDav sync with Radicale: No categories
can we get a test account on this server?
Unfortunaly, each CalDav server has own interpretation of RFC, and working around them is not always possible.
EssentialKURT
This is a local server on Debian Linux, running in a virtual machine. I could upload you the virtual machine image for Virtualbox.
Just to add: Thunderbird is handling the CATEGORIES without problem with this server.
Yes, it would be great to get virtualbox image so that we could reproduce the issue reliably. Please send me the link to the file and some instructions to reproduce the issue.
EssentialKURT
I have just emailed you the download link.
EssentialKURT
Could you test the server on the virtual machine?
EssentialKURT
It is quiet here. No further actions planned to adress the issue?
EssentialKURT
Time goes by - anybody here?
unfortunately looks like the problem is in some Radicale peculiarities, which require some changes on EPIM side especialyl for this server. So far we did not have possibility to work on that.
