No Undo action in Contact records?!
- Has thanked: 17 times
- Been thanked: 43 times
Win 8.1 x64, EPIM newest Pro Biz.
I have just discovered that UNDO command, either from Menu or Ctrl + Z does not work anymore in Contacts records.
Well, this is surprising.
I have just mistakenly deleted one field entry, a phone number to some CEO, and wanted to get it back, as usually. Pressed Ctrl + Z, nothing.
I was lucky it was in the backup.
Could you revert it back, ie. make this option to undo in contacts fields available again?
Cheers,
Piotr
Cheers,
Piotr
Win 10 Pro 64x
Win 10 Pro 64x
Re: No Undo action in Contact records?!
it works on my tests. Please post screenshot, showing how exactly and what you delete. It may heavilty depend on steps and sequences.
I will.
During these works the action Undo in Main Menu is also unavailable. So not only Ctrl + Z does not work.
Win 10 Pro 64x
Win 10 Pro 64x
It works now with shortcuts, ctrl+z,
but still no active option in Main Menu > Edit.
Win 10 Pro 64x
Win 10 Pro 64x
