[solved] How could I see with which Google account the sync is set?
Trinitylab
Has thanked: 17 times
Been thanked: 43 times
Post by Trinitylab »
EPIM newest Pro Biz.
Long time ago I set a sync with Google.
I do not remember with which account though, we have several business ones.
How I can check it?
I do not see any field or information in 'Edit Synchronization" or whatsoever.
Look forward to hearing from you Guys,
Piotr
Win 10 Pro 64x
Re: How could I see with which Google account the sync is set?
please go to Tools-> Options-> Synchronization and see all your synchronizations set up there.
Trinitylab
Hi Max,
Thanks for the reply.
I know that, but there is nothing there about "the Google account set to sync with".
Actually, these are the same options visible as in File > Sync > Edit Sync.
PS I have found the terrible workaround: log file. There I can see with which google account it is syncing.
Really, it should be visible in the options ie. Edit Sync.
Win 10 Pro 64x
you are right, it is not possible to distinguish between Google accounts. We will see when we can get that improved.
Trinitylab
Thank you, Max.
I know it is a matter of time, not the difficulty.
So far, log file in Edit Sync can be helpful.
Win 10 Pro 64x
Trinitylab
Thanks, seems to be done in 8.1, thank you, Guys!
Win 10 Pro 64x
