New tester - first impressions
Overall, pretty good. Sync is easy and fast.
I would prefer to see the options when I choose to sync though - right now it's very easy to hit "sync" and then go "ack! didn't mean to sync contacts!" or whatever. I'd like one step in-between, to confirm what should be sync'd.
Problem with recurring all-day events: when I enter a recurring all-day event on my pda, then sync it, the first occurrence of the event is showing up one day too soon in EPIM. For example - I enter "Bob's birthday" or "meeting with Joe" on December 30th, then sync - on the pda it's fine, but in EPIM, the first one shows up on Dec 29th. All following incidences of the recurring event are fine.
No problems with contacts or tasks so far.
Running W2K Pro and a HP iPAQ with Win CE 3.0
Oh - and I've noticed an issue with EPIM itself. The Autosave allows me to change how frequently the program autosaves, but the change doesn't stick - when I re-open the dialog box, it's set back to autosave every minute.
