Problem with my PPC portable key
clauderenaud
Beta Team
Post by clauderenaud »
Hi staff and all,
My Epim PPC portable key is no longer recognized.
Each time I click on File/synchronization/pocket pc I receive the following error message : "Confirm
PPC Sync requires PPC License. If you have purchased one, please insert license code into Help -> Registration. If you want to buy PPC license, please
visit PPC Sync web page."...
I don't know since which version it occurred but I just noticed this whereas everything worked well until now ...
regards,
Claude Renaud
Been thanked: 363 times
could you post the screenshots of both the window asking for a code and your Help-> About window...
clauderenaud
Beta Team
Max wrote:Hello,
How to acomplish this, blinds are really unfriend with those things !!
And how to post them ....
I have to say that I even redownloaded my key and replaced it but with no success....
As far as I remember in 1.81 it works !!!
Here are the two screen (in textual form)..
1. The screen asking for a valid license :
Confirm
Yes no
2. My about box.
About EssentialPIM
EssentialPIM Pro Portable v. 1.82
Copyright © 2004-2006 EssentialPIM Ltd
WEB: www.essentialpim.com
Email: epiminfo@essentialpim.com
English localization: EssentialPIM Ltd
Registered to: Claude Renaud
OK
regards,
Claude Renaud
kcshaw
Post by kcshaw »
With EPIM 1.82 running on Win2000 I'm having what appears to be an identical problem. I only recently purchased the PPC upgrade so can't comment on previous versions of EPIM, but have been unable to successfully enter the new provided license key in 1.82 and the error descriptions posted above are the same.
No images/captures to show this in more detail atm.
Thanks everyone.
Can you please send me (preferably on the forum, using PM Me! button below my message) your:
- license name
- license code
- are you using Portable or Desktop?
so that I check them?
There is basically no time limit on these keys and they should work fine. But seems something went wrong. If keys are in fault, we will promtly issue new ones for you.
Got the problem reproduce, no need to send keys. Will revert with a fix ASAP.
Hello everyone,
thank you for posting about the problem! Issue fixed, please re-download fixed distributives from here: http://www.essentialpim.com/?r=download and re-register if needed.
clauderenaud
Beta Team
Max wrote:Hello everyone,
But how to register as you send me a essentialpim.ini registration file when I bought this version ?
When I keep the information present in the ini file ane try to register manually, I receive an error ...
regards,
Claude Renaud
Register it exactly like you did it previously. If you are using Portable version, you do not need to enter the key manually.
clauderenaud
Beta Team
Previously, I just copied the .ini file in my portable directory.
This file has always been in this directory and never modified, I even redownloaded my key and saved it again, but sorry to tell you that it does not work ... since apparently the latest version !
regards,
Claude Renaud
clauderenaud wrote:
Max wrote:
clauderenaud wrote: But how to register as you send me a essentialpim.ini registration file when I bought this version ?
You downloaded the wrong key. There are two keys which have been issued to you. One starts with small letters, i.e. xxx_xxxx and another is Xxx_Xxxx. Download the second one. I now deleted the one without PPC edition.
clauderenaud
Beta Team
Max wrote:
clauderenaud wrote:
Max wrote: Register it exactly like you did it previously. If you are using Portable version, you do not need to enter the key manually.
There is something I don't understand because this key hs always worked and I use it since months now...
The key I have, which works since months, begins with a capital letter (E), so it is a correct key
regards,
Claude Renaud
Claude, I will send you your key which works using PM on the forum.
clauderenaud
Beta Team
Max wrote:Claude, I will send you your key which works using PM on the forum.
Big, big, big thanx !!! Now it works as before !
We will never know what happened with that key and why it become suddenly unvalid ... but the most important is here, thanks to you !!! Thank again !
regards,
Claude Renaud
