Great!!
Finally the feature has been implemented that an upgrade can be done within the application itself! This is the best feature for a long time!
Upgrade without download
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Upgrade without download
Thank you! Although, I believe you specifically mean the Portable version?
How is it done?
I've been using EPIM free portable for over 10 years now, finally I paid for the Pro version, and I find no possibility for the actual upgrade, nor a download of a portable Pro version.
lg
nicolleen
lg
nicolleen
Please get the Pro version from here: https://www.essentialpim.com/get-epim (there's a single installation file, download it and follow the on-screen instructions to install the portable version). Once you have it running, all future updates will be happening automatically.
