Script error
windsurfer
Script error
Post by windsurfer »
I use version 8.63 Pro with windows 10
When i try to add a sync i get this error.
I have been using the program now for several days and find all kinds of peculiarities i don't really care for. And the help file might as well be not exist.
windsurfer
Re: Script error
Also no matter what select to do with the error when i get to the page to allow PIM the neccesary items the allow button is greyed out.
Re: Script error
for a test, I suggest running Internet Explorer or Edge and navigating to gmail.com - will it work there?
DavidN
Has thanked: 18 times
Been thanked: 14 times
Re: Script error
Post by DavidN »
windsurfer wrote: Mon Jan 27, 2020 9:22 pm Also no matter what select to do with the error when i get to the page to allow PIM the neccesary items the allow button is greyed out.
I experienced this before. Try dragging that window and enlarging it slightly. Fixed the problem for me.
windsurfer
Re: Script error
Now i am getting this when i try to access my email. I have never had a problem in WLM and with PIM i have all kinds of weird problems accessing my email.
windsurfer
Re: Script error
I hope somebody comes up with a solution because that is my main email address
windsurfer
Re: Script error
I deleted the account that gave me the error and recreated it, I am not getting the error now but i lost all my emails and even though i have my account set to leave a copy on the server it won't download them.
This program is giving me more trouble than i care to admit.
So far i am not impressed.
Re: Script error
I must admit, indeed, you are having quite an unusual number of issues one could expect. Difficult to explain the common reason, thus tackling issues one by one.
If your email account was IMAP, and account was deleted and then created again- emails should definitely appear in EPIM. Screenshots of your set up, of email receiving window would help to understand possible issue.
windsurfer
Re: Script error
No my account are pop3 and marked as leave a copy on the server
Re: Script error
If you make a new account and email is not downloaded, most likely it's because server does not expose those emails. To test, you can try another email client to use with same mail account.
goldpony
Re: Script error
Post by goldpony »
DavidN wrote: Wed Jan 29, 2020 1:00 pm
I'm having this same problem and I can't drag it or anything. I can open Gmail on the edge. Can you please help me?
Re: Script error
goldpony wrote: Fri Feb 14, 2020 7:32 pm I'm having this same problem and I can't drag it or anything. I can open Gmail on the edge. Can you please help me?
for a test, I suggest running Internet Explorer or Edge and navigating to gmail.com - will it work there? If not, please post screenshot of the issue.
goldpony
Re: Script error
Post by goldpony »
can I do EssentialIPIM pro online instead of download the software?
goldpony
Re: Script error
Post by goldpony »
This is what showing when I'm trying to add gmail.
goldpony
Re: Script error
Please update to EssentialPIM 8.64, will there be the same problem?
