Issue updated from 8.63 to 8.64 can't open my database
- Has thanked: 7 times
- Been thanked: 2 times
Hi
i have updated from 8.63 to 8.64 under w10 pro 64bit and i can't open anymore my database , and this does happen only under w10 , w7 works great
i use the pro portable , i had to go back to 8.63
i had these errors ,is there a fix?
thanks
thanks
Code: Select all
Dynamic SQL Error
SQL error code = -204
Table unknown
CONNECTIONS
At line 1, column 38.
- Been thanked: 1134 times
Re: Issue updated from 8.63 to 8.64 can't open my database
Thanks for the report, we're investigating it. Will update this post once I have more info.
Please redownload and reinstall the 8.64 version, that should fix the problem.
hiadmin wrote: Wed Feb 12, 2020 6:47 pm Please redownload and reinstall the 8.64 version, that should fix the problem.
nothing
md5 8a2eced3ff9229f6756ab5f485e9fac3
sha1 e113189588916a2f6b42319de0cfe802ecbb1f24
sna 256 ca045273a7a00a0443881720a0062c9e2ed614a64a11473162ef4ac0c051bb86
i have download it again and the hash is the same
maybe it's windows System : Workstation, Version: 10.0, Build: 4563,seeing under w7 work perfecly
thanks
Does not seems to fix this issue. same error. Tested on Win7 X64.
Seems to pro business related issue. Did not face on my personal db running usb drive.
File downloaded - EssentialPIMPro.exe
SHA-1 -e113189588916a2f6b42319de0cfe802ecbb1f24
VerDB- 4.02, 4.24, 4.51, 4.52, 4.54, 5.03, 5.5, 5.51, 5.52, 5.53, 5.54, 5.55, 5.56, 5.57, 5.8, 5.82, 6.0, 6.01, 6.02, 6.03, 6.05, 6.06, 6.51, 6.52, 6.53, 6.56, 6.58, 7.54, 7.66, 8.11, 8.14, 8.15, 8.5, 8.51, 8.52, 8.53, 8.54.3, 8.6, 8.61.1, 8.62.1, 8.63
Sorry, seems the installation file didn't get properly updated the first time. Please try again.
SHA1: DF59CCA66F414D1312C57DE132246A1D30076527
SHA256: 9C8C7644D8E4C2D91737B059A329FBDA5873EA003F3D7E1720AA2B50E011348D
Downloaded updated file.
Issue fixed
Issue fixed
hiadmin wrote: Wed Feb 12, 2020 9:28 pm Sorry, seems the installation file didn't get properly updated the first time. Please try again.
downloaded and works under w10 pro 64bit
thanks !
And thank you for the confirmation!
- Has thanked: 17 times
- Been thanked: 42 times
Hi, 8.64 is not available with automatic update yet?
Win 10 Pro 64x
Win 10 Pro 64x
It actually should be. If you haven't got it, yet, please wait a bit - it's going to reach you either today or tomorrow.
Thanks, no problem, just wondering, I click 'check for updates' and nothing.
Win 10 Pro 64x
Win 10 Pro 64x
