Outlook 365 calendar sync.
When I try to do a two-way sync on my calendar, it fails saying the calendar is read-only, which it's not because it works fine with Outlook and other apps I use to sync to it. One way sync from the calendar works, obviously, but how do I fix this issue?
Re: Outlook 365 calendar sync.
- Has thanked: 1078 times
- Been thanked: 742 times
EPIM is able to sync as with your local Outlook installation and with Outlook 365. Not sure why you needed to use Google as an intermediary step here.
- Been thanked: 1 time
I have the same issue.
For testing I started with a new database and did a initial synchronisation which worked!
But after the intitial sync each further sync stops, because the calendar is read only?! And as calendar-sync stops, to-do's, notes, contacts can't sync as well. After the initial-sync only mail stays in sync.
Then I tried it with my EPIM-Database in use = I couldn't even make a initial synchronisation, because calendar is 'read-only' and sync stops.
I'm using EPIM-ProPortable, Lifetime-License, with Language = German, and Windows10 Business 64bit.
Please have a look on this issue, because if this works, this would be a killer feature - highly appreciated!!
Thanks and best regards, Michael
Thank you for reading my message!
Michael
Michael
In order for us to have a look, we need to see a log file, please forward it to us. The log can be found here: Tools->Options->Synchronization, Browse... and its filenames should start with "OutlookSync".
Please find attached the log-Files.
Best regards, Michael
Michael
Michael
Please delete asap! Thanks!
Michael
Michael
Thanks, got the log files. Will have a look at them.
