[Bug] Unexpected change of default calendar view
lk
Has thanked: 11 times
Been thanked: 5 times
Post by lk »
Hi there,
I'm not sure if this behaviour changed during some recent update, but I'm pretty sure I would have noticed it earlier if it wasn't the case:
I have placed the "Calendar" icon on my Android home screen because it is the EPIM module I mostly use on my smartphone. When I click on it, the calendar always starts in the "Day" view, no matter which view was active when I closed the app the last time. It's 100% reproducible here:
  • Start EPIM calendar from the icon
  • Change the view to a different one (my preference is "Month")
  • Leave the app (= go back to the home screen
  • Reopen EPIM calendar from the icon
The view is reverted back to "Day", which is annoying as in most cases I have to switch back to my preferred view "Month" manually.
If I start EPIM from the launcher and choose "Calendar" from there, the last shown view is reused. Because the app behaves differently in the aforementioned cases I'd consider this more a bug than a feature.
(EPIM for Android 5.7.2 on Android 5.1)
lk
Has thanked: 797 times
Been thanked: 427 times
Re: [Bug] Unexpected change of default calendar view
Confirm this issue, will be fixed in the next update. Thanks!
lk
Post by lk »
Seems to be fixed with v5.7.3. Thank you.
lk
