EPIM sync Outlook Notes with two PST files
Laurent C.
Post by Laurent C. »
Hi
I receive :!: exception errors in EPIM PC when trying to add a 2nd Outlook sync for my Notes
And my EPIM Android became unable to connect to the PC with :!: connection errors
And the notes were all mixed up between EPIM PC and the 2 PST...
Deleting the 2nd Outlook sync corrected the exception and connection errors altogether
:arrow: So, it seems EPIM does not really work with more than 1 Outlook PST file
Regards
Max wrote:
Mon Jun 01, 2020 10:37 pm
EPIM in principle works with multiple Outlook files, however, it is important to sync with them one by one and never simultaneously.
EPIM Pro + Office 2019 Pro FR + EPIM Android (SGN9) / Win 10 Pro 64 FR / CPU Ryzen 9 3950X + Z63/ GPU RTX 2080 Ti + G12 + H55 / CM Crosshair VIII Impact / SSD 2TB PCie 4.0 5000 MBps + HDD 3TB / RAM 32GB DDR4-3600-CL16 Trident Z Royal Gold / RGB HUE 2 NZXT
Laurent C.
Re: EPIM sync Outlook Notes with two PST files
Hi
I use simply the Synchronize All (Ctrl+Shift+Z), sometimes
And configuration Synchronize start / exit / 15 minutes
It's standard in the tool and that shall give the good result 1 by 1 without triggering an exception, no ?
Regards
Laurent C.
Hi
I have proceeded to the test anew with EPIM for my distributed notes :idea:
I have a PST file synced with EPIM PC using the config OUTLOOK and EPIM PC synced with EPIM Android using the config ANDROID : perfect !
I create a new PST file synced with EPIM PC using a third separate config named OUTLOOK_TEST
At this moment, it became impossible to me to connect with EPIM Android to EPIM PC : connexion error
But, strangely, it works with that second trying...
Forget it :mrgreen:
Anyway, when starting EPIM PC, I get the systematic error :
EPIM startup sync error
When using Synchronize All (Ctrl+Shift+Z) same error !
There are no logs but an AndroidSync file inside C:\Users\Laurent\AppData\Roaming\EssentialPIM Pro\Logs :
EssentialPIM Pro 8.66.1 07/04/2020 12:08
14:57:03.503 9112 Server started at port 21114
14:57:03.503 9112 Local IP address(es):
14:57:03.504 9112 192.168.1.16
14:57:03.504 9112 192.168.1.10
14:57:05.508 9112 Server stopped
Regards
Laurent C.
The error is triggered when using Synchronize All (Ctrl+Shift+Z) that is, however, a standard EPIM synchronization function... :roll:
Laurent C.
Regarding issue with Notes folder- we will be looking into the issue, but that will take time.
Hi Max
Now you got time to debug EPIM 9.0 while releasing 9.3, did you also get time to cope with the EPIM bad logic below for managing multiple PST files ?
:arrow: The error is triggered when using Synchronize All (Ctrl+Shift+Z) that is, however, a standard EPIM synchronization function...
Regards
Has thanked: 794 times
Been thanked: 426 times
Will attempt to address the issue in the new 9.4 version. Thanks!
Laurent C.
Wow : efficient ! :D
