ICS-Import funktioniert nicht mehr
mb65
Post by mb65 »
Seit dem Update auf V9 (portable) funktioniert der Import meiner bisherigen ICS-Dateien nicht mehr:
BEGIN:VCALENDAR
CALSCALE:GREGORIAN
VERSION:2.0
BEGIN:VEVENT
DTSTART:20200609T140000
DTEND:20200609T150000
SUMMARY:Name
CLASS:PUBLIC
CATEGORIES:Geschäftlich
LAST-MODIFIED:20200602T144546
UID:00000000AA8EE6AF20645B4CA027A5348757B10D445C1101
END:VEVENT
BEGIN:VEVENT
DTSTART:20200610T110000
DTEND:20200610T130000
SUMMARY:Name2
CLASS:PUBLIC
LAST-MODIFIED:20200605T170841
UID:00000000AA8EE6AF20645B4CA027A5348757B10D64661101
END:VEVENT
BEGIN:VEVENT
DTSTART:20200610T140000
DTEND:20200610T160000
SUMMARY:Name3
CLASS:PUBLIC
LAST-MODIFIED:20200606T125930
UID:00000000AA8EE6AF20645B4CA027A5348757B10D64681101
END:VEVENT
BEGIN:VEVENT
DTSTART:20200611T000000
DTEND:20200612T000000
SUMMARY:Fronleichnam
CLASS:PUBLIC
LAST-MODIFIED:20130601T105849
UID:00000000AA8EE6AF20645B4CA027A5348757B10DC4A2E100
END:VEVENT
BEGIN:VEVENT
DTSTART:20200618T140000
DTEND:20200618T160000
SUMMARY:Name4
CLASS:PUBLIC
LAST-MODIFIED:20200604T120105
UID:00000000AA8EE6AF20645B4CA027A5348757B10DC4611101
END:VEVENT
Woran liegt es?
mb65
Re: ICS-Import funktioniert nicht mehr
Post by mb65 »
Sobald die Datei irgendeinen Umlaut enthält wird gar nichts importiert
das ist eindeutig ein BUG!!
mb65
Post by mb65 »
Scheint keinen zu interessieren
OK
Has thanked: 794 times
Been thanked: 426 times
Sorry for the delayed reply. I saved your data into an ics file and imported it into EPIM 9.0. See the screenshot attached of what was the outcome of such import (5 events were imported).
Although, I can confirm a minor issue when the category was imported as "Geschaftlich" and not as "Geschäftlich" (with an "ä").
Please check if you're able to import your ics file into the new EPIM database. Will it work?
mb65
Post by mb65 »
I have written a little vbs script to export some Outlook entries as an ICS-FIle (like the one above!)
The original file ist NOT imported.
Now I tried some copying. After copy and paste to a new file it works.
What might be the reason that the created file via VBS-script is NOT working? I did NOT have this problem in V8
We'd like to see and check that exported ICS file first. Please send it to me via PM. Thanks!
mb65
Post by mb65 »
did you get my PM??
or is it stuck as my picture implies?
Yep, got it, thanks, looking at it. Will update this post with more info.
mb65
Post by mb65 »
I installed 9.1
Now the german Umlaute are wrong coded like ü for ü
CATEGORIES:Geschäftlich is not imported
the only thing better (it seems) that Umlaute are no longer items, that are not impoorted at all
I tried to export some items from EPIM and reimported them with the same problem like above!
And I want to remind you: all this troubles did NOT occure in v8
Please forward me couple of ICS files that do not work for you.
mb65
Post by mb65 »
I have allready sent you
mb65
Post by mb65 »
Step by step:
Then I exported it directly from within EPIM - this "test.ics" is the result
As soon there are Umlaute involved it no longer works correctly.
Sometimes the entries are not imported at all. The category "geschäftlich" is not set correctly
The Umlaute are all wrong coded!!
And again: This was not the case in EPIM 8!
test.ics
(368 Bytes) Downloaded 7 times
Thank you, problem reproduced, will attempt to fix in the next version.
mb65
Post by mb65 »
I now solved the other problem with my script
I used object.OpenTextFile (filename, [ iomode, [ create, [ format ]]]) with Format ASCII. Now with UNICODE all is working fine...
