Using V9.0 pro
In the tasks module I've added a couple of custom tabs and added some tasks, they appear OK in the correct tab but don't appear in the "All" tab - I assume they should.
I've only just started using the tasks module so I'm not sure if they appeared in previous versions
Paul
Tasks not appearing in "all" tab
Paul
http://www.ipgphotography.com
EssentialPim-Pro, Windows10 64bit
Re: Tasks not appearing in "all" tab
If you created the "All" tab yourself, EPIM wouldn't know that it should treat it differently than all the other tabs. If you wish to see all tasks on one screen, please choose the Consolidated option.
Ok, thanks for the reply - I must have created that some time ago and forgot I had done so - I assumed it was a default tab.
blame old age
Paul
blame old age
Paul
Paul
