How to insert picture in Note
swwhit52
Post by swwhit52 »
Sorry if this topic has been covered but several searches proved unsuccessful.
I set up a couple dozen notes and would like to insert a photo in each one. Easy enough to do in Windows version.
I was able to select & insert from the Gallery.
When I clicked on the camera icon in the note menu, I was able to take a picture, but it did not appear in the note.
I'm not sure if any of the other menu icons are related to this.
If there is a help file or tutorial on this subject, or any other tricks, please let me know. Thanks in advance.
Has thanked: 798 times
Been thanked: 429 times
Re: How to insert picture in Note
The way you did it was the right one. Although, did you tap on the Save icon after you took a pic?
swwhit52
Post by swwhit52 »
I tried it and it worked fine. Is there any way I can resize and/or crop the image? I don't need it full-size and want to keep the file size down.
Gallery is still driving me nuts. I can crop/resize, etc, and it saves the image, but does not save it to the same folder that I got it from and I see no way to tell it what folder to save to. But that isn't a problem with Epim. I don't know how you folks keep your sanity working with Android but I give you credit for doing it!
You can crop an image at a time of adding it and then once added, long tap on it in order to resize.
