the font colour of completed items
dirmansyah
Post by dirmansyah »
After I set an appointment as completed, epim changes the font colour to light-gray and it is struck-through.
It is hard to read light gray in light theme. If I use dark theme, its readability is worse.
To me, the strike through is enough to show that the item is completed.
Is there any option to set so that the font colour of the completed items will not be changed ?
Has thanked: 876 times
Been thanked: 497 times
Re: the font colour of completed items
There's no such option, unfortunately. Will make the font color darker in the next version. Thanks!
dirmansyah
The default colour set by the app (without an option to disable it) is not a good solution in this case. Please consider that users should be free to set the back ground colour for the categories.
You can already set colors for categories. Or you mean something else?
