Import passwords (CSV) with German Umlauts errorneous
VolkerM
Has thanked: 12 times
Post by VolkerM »
I imported an csv file (; separated) with German Umlauts. The German Umlauts are not decoded or maybe recoded correctly.
E.g. "Böttcher" becomes "Böttcher", "Schlüssel" becomes "Schlüssel", "Postfächer" becomes "Postfächer", " – " becomes " – " etc. (The latter one isn't a German Umlaut but a graphical sign, a dash).
I am using EPIM Pro 9.2 on a Windows 10 Notebook.
Has thanked: 794 times
Been thanked: 426 times
Re: Import passwords (CSV) with German Umlauts errorneous
Was the CSV file stored in the UTF-8 (Unicode) encoding? If you could edit the file, leaving just couple of unimportant entries without passwords and forward to us, we would have a look at it. Thanks!
VolkerM
Post by VolkerM »
Yes, it was. to ensure this, I imported it into Excel and exported it again as a csv file with codepage set to utf-8. Importing this led to the same error.
I shortened it and attached it. Thanks for your support!
Passwortexport_sample.txt
I had to rename the extension from csv to txt because of the phpBB import filter !
(1022 Bytes) Downloaded 8 times
mb65
Post by mb65 »
I found out that Windows Editor is not working correct with coding of UTF-8
Try changing the coding with notepad++
(like in the attached screenshot)
VolkerM
Post by VolkerM »
I did the export again and shortened the csv file (w/ Notepad++).
From the beginning Notepad++ displayed it as utf-8 encoded. Umlauts are displayed correctly. See screenshot!
Then I imported this csv file to EPIM and found the Umlauts displayed errorneous. See second screenshot!
Notepad++ screenshot showing utf8 encoding
EPIM screenshot showing the result of the import
mb65
Post by mb65 »
Konvertiere zu UTF-8 auch probiert?
Keldi
Been thanked: 40 times
Post by Keldi »
Converting into UTF-8 with BOM in Notepad++ should do the trick as EPIM will recognize the coding correctly after that.
VolkerM
Post by VolkerM »
Excellent! That did the trick. :D
Thank you very much, Keldi!
mb65
Post by mb65 »
Als ob ich was ganz anderes gepostet hätte...
VolkerM
Post by VolkerM »
DIe Konvertierung nach UTF-8 (ohne BOM) hat nicht funktioniert!
