Calendar
Vote for your favorite feature requests to make them into EPIM’s roadmap
Vote for Calendar features that are important to you
Ability to set time zones for appointments. (EPIM-106)
3
2%
Forward reminder notifications by email. (EPIM-164)
4
3%
Alternative way to quick add tasks into calendar by holding down the Ctrl key and selecting time period with a mouse cursor (EPIM-568)
4
3%
Convert to task option in the appointment edit dialog and context menu.
8
6%
Automatically move an appointment to the next day if not complete (EPIM-901)
11
8%
Option to change completion slider in the edit dialog to drop down list with values. (EPIM-918)
6
5%
"Last day of the month" among repeat options. (EPIM-939)
13
10%
Generate spent time reports for a specified period of time. (EPIM-1039)
2
2%
Option not to keep event duration when editing start date, so that end date isn’t adjusted automatically. (EPIM-1135)
5
4%
Option to use a picture as Calendar background. (EPIM-1143)
7
5%
Indication of last event in the recurring series. (EPIM-1389) - DONE
9
7%
Ability to show notes in calendar using their creation/modified dates (might be useful in a sense of making and keeping a diary) (EPIM-1391).
9
7%
Choose how to sort all day events on the same day (alphabetically, by priority, by created date, etc.) in calendar views (except for the Table view). (EPIM-1753)
4
3%
Show weather on the calendar. (EPIM-2140)
8
6%
Create new appointment when you drag&drop a file to the calendar. The file will be added as an attachment to the newly created event. (EPIM-2260)
9
7%
Make a templates dialog window bigger in order to accommodate longer template names and add the date column to show creation dates of templates (EPIM-2262)
3
2%
Feature to jump from a table view to the selected appointment location, so you could quickly review what's around the selected appointment on any of the calendar views. (EPIM-2338). - DONE
5
4%
Option to fill in specific day(s) in the calendar with a selected background color. (EPIM-2425)
9
7%
Bulk change dates for selected appointments. (EPIM-2427). - DONE
5
4%
Ability to assign categories to evens when importing them from iCal files. (EPIM-2478)
3
2%
Add assignees to appointments as in tasks. (EPIM-2543)
2
2%
Export the duration field as date (not text) to CSV files. (EPIM-2586)
1
1%
Total votes: 130
Has thanked: 934 times
Been thanked: 554 times
Calendar
If you wish to see a certain feature implemented in EssentialPIM, vote for it so that we know how "wanted" a feature is by looking at the number of votes it gets.
We didn't impose any limitation on the number of features you can vote for, although please keep in mind that our resources are limited and therefore vote only for the ones you really need.
Re: Calendar
Implemented in EssentialPIM 9.6 (22-Dec-2020)
- Indication of last event in the recurring series. (EPIM-1389)
- Feature to jump from a table view to the selected appointment location, so you could quickly review what's around the selected appointment on any of the calendar views. (EPIM-2338)
- Bulk change dates for selected appointments. (EPIM-2427)
dirmansyah
Re: Calendar
Post by dirmansyah »
Hello, admin,
For this one:
"Ability to show notes in calendar using their creation/modified dates (might be useful in a sense of making and keeping a diary) (EPIM-1391)."
To make the note items appear in calendar:
Will we be able to filter the note items based on:
1. the period (e.g. notes modifed from Jan 01 till Jan 25 ), or
2. based on the Tree name (since there is no category in note module)
Or,
Should we select a note item manually?
Re: Calendar
The idea is to offer same filtering mechanisms as if you were searching/filtering for appointments or tasks shown in calendar.
dirmansyah
Re: Calendar
Ok.
What about the TreeName field?
Will we be able to include the TreeName field in the filter-set ? (e.g. filter by creation date, and by TreeName fields)
I wish we will be.
Re: Calendar
I don't know we haven't though about the feature in such details, yet. Although, thanks for the feedback, will take it into consideration.
