Android EPIM 5.8
It does not work as for the notes fixing, but translation is correct
When I use the Android back button, then it forces a saving while nothing is modified
Regards
EPIM Android - Contact systematically saved even if no change
- Laurent C.
- Has thanked: 4 times
- Been thanked: 12 times
Re: EPIM Android - Contact systematically saved even if no change
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
- Has thanked: 1424 times
- Been thanked: 990 times
Will be addressed in the next update.
- Laurent C.
Thank you !
