Exit without saving will not work, the application will overwrite and delete.
marmegint
Post by marmegint »
An event that repeats once every two weeks, if i edit but are not gone, than choose the cancel command and then the back arrow (bottom), the application will enter the event every day.
Another event that was on the original day is deleted.
I only looked at the rule in the custom repeat menu.
Opening the event for editing (again) in the same way and exiting without modification will delete the event too.
(My phone is Sony Xperia 1, Android 9, AEPIM v5.7.4.)
Has thanked: 876 times
Been thanked: 497 times
Re: Exit without saving will not work, the application will overwrite and delete.
I'm not sure we're able to reproduce the problem. Please record a small video indicating the issue.
marmegint
Post by marmegint »
I record a small video, but i can't upload here.
Nothing is posed at the moment to the attachments section.
Am I not doing something right?
An error occurred: "File too large"
File size is: 8,64 MB
What is the file size limit?
Thank you, reproduced, will be fixed in the next version.
marmegint
Post by marmegint »
This is good news.
marmegint
Post by marmegint »
Is it possible to have the custom repeat also appear if we look at the details of the entry?
No need to open editing for that.
(The normal repetitions are displayed.)
It would also be useful to save only the check mark (save button)!
Do not save on back button(s) or at exit, close or collapse.
This would be good for the all modules as well.
Thank you.
Will try to implement that, as well.
