Android Sync Frustrations...
bobmac1547
Been thanked: 12 times
Post by bobmac1547 »
Syncing with Android takes over 30 minutes and still does not complete. I abandon. And I've got lots of duplicates in my Android calendar that I'm trying to delete but checking off "sync deletes" does not work. I'm only Syncing one way (TO Android) until this is fixed, but it's very frustrating.
And automatic syncing every 15 minutes flat out does not work.
Android: 5.7.4
PC: 9.5.2
Log attached
AndroidSync_2020_12_07_17_09_30.zip
(221.89 KiB) Downloaded 332 times
Re: Android Sync Frustrations...
Please try to restart EPIM, will it help?
bobmac1547
Restarting the PC version allowed the sync to happen, but the Android version just kept spinning and spinning. I stopped the Android after about 15 minutes and checked the PC. Changes had been sync'd, but there are still some issues.
In this case we'd need to see the updated log file. Thanks.
bobmac1547
Here's the updated log...
AndroidSync_2020_12_10_14_35_15.zip
(128.79 KiB) Downloaded 359 times
Thanks, will try to fix this in the next update. Meanwhile, EPIM's restart should fix the issue.
cdc
Post by cdc »
bobmac1547 wrote: Tue Dec 08, 2020 3:40 am Syncing with Android takes over 30 minutes and still does not complete. I abandon. And I've got lots of duplicates in my Android calendar that I'm trying to delete but checking off "sync deletes" does not work. I'm only Syncing one way (TO Android) until this is fixed, but it's very frustrating.
Android: 5.7.4
PC: 9.5.2
Log attached
Have you tried to restart it? I think it sounds a little stupid but that's what helped me
johncesta
Been thanked: 11 times
Android sync is better but....
Post by johncesta »
Android sync is significantly better but...
I add an image to an android note and it syncs to my pc. The image is in google drive. But then later it does not display on the phone. It just leaves a place holder.
John Cesta
Knights of Columbus
johncesta
Post by johncesta »
Then later it displays on the phone...then it doesn't. I reboot too yea.
John Cesta
Knights of Columbus
