EPIM Cloud Sync - Notes not syncing related items
DavidN
Has thanked: 9 times
Post by DavidN »
On PC1, I have setup a note to include 8 different related calendar items to that note. I then sync using EPIM cloud. Then I sync to PC2. The note transfers perfectly, however, the related items do not sync to PC2
Is this normal?
Thank you.
Has thanked: 931 times
Been thanked: 545 times
Re: EPIM Cloud Sync - Notes not syncing related items
Related items should be synchronized. Please forward us the sync log file, will have a look.
DavidN
Post by DavidN »
Thank you. My apologies, but where would I find the sync log file?
The log files can be found here: Tools->Options->Synchronization, Browse... and the filenames should start with "EPIMCloudSync". Thanks!
DavidN
Post by DavidN »
Thank you. I just sent to support.
Great, thanks!
