Android Epim problems
dirmansyah
Post by dirmansyah »
🔴 A&W-epim Pro strike through & change text colour of my completed items. Provide option to disable that behaviour. 🔴 A-epim does not support table. 🔴 A-epim can not use camera and insert the pict in a note. (neither recorded sound). 🔴 A-epim takes so long to open "Oxford 3000-word list" (text) in Note module and blank screen appears before and after displaying the text. 🔴 Can not backup. Can not make new folder for backup.
The above is what I wrote on google play review for epim.
What is going on with android-epim development?
The more I try to use it, the more problems I face.
Currently I only use note (dropped the others) but still the obstacles are there.
Has thanked: 973 times
Been thanked: 594 times
Re: Android Epim problems
1. Noted.
2. We're aware of that.
3. It can use camera.
4. This is already known, please do not duplicate your requests.
5. Describe in details what happens when you try to.
janicetr
Post by janicetr »
I have only one (and not so serious) problem to report: Tasks considers sunday as the first day of the week and all my sunday due tasks are groupped to "Next Week". Can you please think of the non-USA part of the world and implement an option just like in the Calendar?
Most likely your system language is set to English (United States), you can change it to English (United Kingdom) and get the correct start of the week day - Monday.
janicetr
Post by janicetr »
Thanks, works like charm! :-)
