Bug: Editing pane doesn't always save
pchandler
Has thanked: 4 times
Post by pchandler »
So this is using EPIM 9.6 on Windows.
When using the editing pane in Contacts or Passwords (ie. the pane that appears on the bottom or right when you single-click select an item), you can use it to edit the information in the item, for instance modify the email associated with the item.
However, there is a small bug - try editing the email for example, but then instead of clicking away, press tab to jump to the next editing field. Now click away, and you will see the edit has not been saved. The only way to save the edit then becomes having to click away first.
I hope this is an adequete description.
Re: Bug: Editing pane doesn't always save
Unable to reproduce. Was the edit saved when you pressed the Tab button?
Keldi
Has thanked: 26 times
Been thanked: 92 times
Post by Keldi »
EPIM Pro Portable 9.6.1.
In a password entry I typed:
new title
TAB
new name
TAB
and then switched to another entry and back.
The new title was saved, but the name returned to the old one.
The same happens with ENTER instead of TAB.
An animated GIF in the attachments.
Got it, thanks, will fix.
