KmxSoft
Been thanked: 8 times
Post by KmxSoft »
I'd like to express my thanks to the authors of EPIM. The recent addition of a right-click menu option on a folder for creating a rule is a great enhancement which will enhance my use of the product when needing to set a filter. So well done guys.
A subtle but significant improvement of this menu option would be to add an edit for a rule already defined, so that adding a filter to an existing rule would make it better. Otherwise it requires the existing rule to be accessed via multiple menu's. I typically have folders to receive emails from multiple sources.
Has thanked: 996 times
Been thanked: 617 times
Re: Thanks
Thanks for your appraisal! Will take a look at the suggested change, as well.
