Not returning to correct place on page.
VictorParkerPIM
Has thanked: 9 times
Been thanked: 51 times
Post by VictorParkerPIM »
Hi Admin,
When I'm reading something in a Note that scrolls two or three pages and I'm near the end of the note, I switch to another Note and return.
It does not return to where I was reading, it goes to the top of the Note. I use another program that returns back to where I was reading when I switch from another note. EsentialPIM returns to where left mouse button was clicked. Can it be fixed where it will return to where the page was scrolled to?
Thanks,
Vic
Win11 Pro Ver. 21H2 (OS Build 22000.282) 64-bit, 32GB Ram, 4K Monitor, EPIM Pro Life 9.10.8
Re: Not returning to correct place on page.
Will try to make it so, thanks!
VictorParkerPIM
Thank you!, Great
Tester
Has thanked: 17 times
Been thanked: 8 times
Post by Tester »
VictorParkerPIM wrote: Wed Nov 10, 2021 12:49 am [...]
It does not return to where I was reading, it goes to the top of the Note. [...] EssentialPIM returns to where left mouse button was clicked. Can it be fixed where it will return to where the page was scrolled to?
Vic, I understand your wish but on the other hand isn't it conceivable that there might be situations respectively users with the opposite preference (= opening a note is performed on top of it)? For my own needs, I am not sure what I prefer. :wink: I think depending on the specific case it may be sometimes the one and sometimes the other solution.
It seems that with EPIM both needs can be satisfied:
a) If you have simply scrolled within a note, the next opening will be on top.
b) If you have clicked somewhere with the left mouse button, the next time it will open there (as you also mentioned). So you can determine the "correct place" by a simple mouse click (like setting a bookmark).
Isn't this better (and more logical) than only a single solution?
It should already work the way Tester suggested.
