Outlook also has a positive feature. If you store an email in a subfolder and reply from there with this email, the reply email is not stored under “sent”, but in the same subfolder. This makes it easier to keep order in the dialogue process.
Is EPIM now also able to save email replies from a subdirectory there and not under “sent”?
If so, how and where can this be set?
Store Email-Answer in Subfolder
Re: Store Email-Answer in Subfolder
I think, EPIM don´t have this feature.
I also store some replies- but only a very few. In most cases I store the answer from my email-partner, not my own reply! Most of my sent emails i do not store and delete them. Why do you want to store your own reply- in most cases you will get an answer which you can store!
If this feature should be implemented, I only want it optional.
It was just a question! But let us hear what admin says. By the way, in outlook it is an option as well.
- Has thanked: 1418 times
There's no such feature at the moment although we can implement it and make optional in one of the future versions.
