Hello together,
Today I noticed that the app does not seem to sync with google calendar.
I set an appointment in Epim to a different time. I also see the moved appointment in the google calendar itself.
But when I look at the app on my smartphone, the appointment is still on the old date.
Pulling it down to reload it does not seem to work.
I use version 5.8.7
Thanks and greetings
Google Kalender Sync
- Has thanked: 1078 times
- Been thanked: 742 times
Re: Google Kalender Sync
Unable to reproduce this. Please first try to disable and then re-enable synchronization.
Reinstall may help in this case. Just make sure to backup your data first, just in case.
