A couple suggestions
Lycanbacca
Post by Lycanbacca »
Have been using your program for a few months and have two suggestions.
1. Have sticky notes that are attached to an event pop up when the event occurs.
2. A "cancelled" option in the task/appointment completion status drop down.
Re: A couple suggestions
1. Noted, although as you may already know, you can put stickies to sleep for a pre-defined period of time, if needed.
2. Noted, as well.
Thanks!
