Ctrl + Space and Alt + Space
VictorParkerPIM
Has thanked: 9 times
Been thanked: 70 times
Post by VictorParkerPIM »
Insert current date and time quickly in last used format using a shortcut (Ctrl+Space by default)
That's the way I always thought it should work.
A great addition would be to use Alt + Space to pull up the Date Menu, to change to another date format.
I really like the 10.1 update, it is very close to perfect. :D
Re: Ctrl + Space and Alt + Space
Thanks for the suggestion, although Alt+Space will not likely work as usually the upper menu gets highlighted when you press on the Alt button. Will think about adding another shortcut for that.
VictorParkerPIM
Shift + Space would be my next choice.
todd
Post by todd »
I was wondering whether the shortcut to insert the date / time in the last format could be made into a variable that we could assign like we do to other keys in the shortcut menu?
VictorParkerPIM
Todd, You can already assign a new shortcut like we do other keys in the shortcut menu.
It's in the Options menu.
todd
Post by todd »
I see a changeable shortcut for Insert Date and Time under the global shortcuts, but I would like to change the key used in the check box at the bottom of the insert-date dialog box that says "Use Shift + Space to insert date and time in last used format". That combination causes me problems when I'm typing sometimes.
VictorParkerPIM
Check box at the bottom of the insert-date dialog box that says "Use Shift + Space to insert date and time in last used format".
Looks like check box and Shift+Space to insert date and time has been removed in Ver. 11.5 Bata1
todd, thanks for the suggestion, noted.
VictorParkerPIM, the checkbox is still there in 11.5 Beta1.
todd
Post by todd »
Ok, thank you
VictorParkerPIM
Admin,
I have not found the checkbox in the Options Menu.
The checkbox is in Notes.
VictorParkerPIM
Sorry, I was viewing the Tools-Options Menu.
