Android Sync / Nextcloud
userfriend
Post by userfriend »
Hi there
I am using EM Client for many years now. For syncing to my Android device, I use my own Nextcloud server.
Back when I decided, it was a close call with EPIM: I liked that EPIM has a dedicated Android app which is not the case with EM client.
Why did I decide against EPIM?
Desktop and Android would only sync via Wifi and not via Nextcloud which is my internet home of all things (tasks, calendar, files).
Has this changed by now?
My setup is working pretty well by now but in some areas, I would like a more integrated solution. However, it is no option for me to sacrifice Nextcloud sync: Google I will not use for obvious reasons (data sovereignty and security), and also switching to a third party solution like EPIM cloud is no suitable way for me.
Has thanked: 1639 times
Been thanked: 1160 times
Re: Android Sync / Nextcloud
Android EPIM is able to sync with EPM Cloud (which is ownCloud based at the moment, however, we plan to migrate to NextCloud in the nearest future). Although, a separate NextCloud sync feature outside of EPIM Cloud is not currently planned (this may change in the future, though).
