application error
中文语言的讨论和支持
leo714
application error
Post by leo714 »
Access violation at address 015C6A47 in module 'EssentialPIM.exe'. Read of address 00000000.
Exception log with detailed tech info. Generated on 2022-07-25 10:05.
Application title: HWW.epim - EssentialPIM Pro
Application: EssentialPIM Pro 11.0.2 2022-07-22
Exception message: Access violation at address 015C6A47 in module 'EssentialPIM.exe'. Read of address 00000000.
Exception address: 015C6A47
Main thread ID = 13024
Exception thread ID = 13024
Object Logs:
10:04:22.436 DBSave OK
10:04:22.435 DBSave
09:59:22.435 DBSave OK
09:59:22.433 DBSave
09:54:22.439 DBSave OK
09:54:22.436 DBSave
09:51:30.590 AppRestore OK
09:51:30.557 SetViewMode OK
09:51:30.377 SetViewMode 0
09:51:30.355 AppRestore
09:51:16.863 AppMinimize OK
09:51:16.796 DBSave OK
09:51:16.794 DBSave
09:51:16.794 AppMinimize
09:49:22.436 DBSave OK
09:49:22.433 DBSave
09:45:44.105 AppRestore OK
09:45:44.091 SetViewMode OK
09:45:43.957 SetViewMode 0
09:45:43.933 AppRestore
10:05:51.740 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
10:05:46.707 ToDoDialog Panel1 StartDateTimePan DateDTP
10:05:45.504 ToDoDialog PageControl1 ToDoTS TitleEd RichViewEdit
10:02:48.657 MainForm FormPan TBXToolbar2 TopTB NewItemBtn
09:51:30.647 MainForm
09:51:15.826 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
09:46:04.129 ExceptionDialog DetailsMemo
09:45:56.107 ExceptionDialog DetailsBtn
09:45:53.726 ExceptionDialog OkBtn
09:45:53.665 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
Exception stack
Stack list, generated 2022-07-25 10:05
(011C5A47) [015C6A47]
(010BDB31) [014BEB31]
(00152045) [00553045]
(00156ACD) [00557ACD]
(002266F1) [006276F1]
(00156110) [00557110]
(000D43EC) [004D53EC]
Memory: 7939; free 2826
Display: 1920x1080 pixels, 32 bpp, 144 PPI
PrevExceptions:
09:44:34.739 Access violation at address 015C6A47 in module 'EssentialPIM.exe'. Read of address 00000000
09:44:45.446 Access violation at address 015C6A47 in module 'EssentialPIM.exe'. Read of address 00000000
09:51:15.693 Access violation at address 015C6A47 in module 'EssentialPIM.exe'. Read of address 00000000
Updates: 1
Last update: 2022-07-24
Has thanked: 1639 times
Been thanked: 1160 times
Re: application error
When does the error message occur, under which conditions?
leo714
Post by leo714 »
在【今天】界面,修改任务就会发生。可能是大版本升级造成的。
This is fixed in the 11.0.3 version. Please update: https://www.essentialpim.com/download-free
leo714
Post by leo714 »
升级到11.0.3,问题依然存在
Working on it, please expect a fix in EPIM 11.0.4. Thanks.
leo714
Post by leo714 »
OK
可能是做了【选项】配置之后,出现的,不确定。
Please download and install the following build, it should fix the problem:
https://www.essentialpim.com/download/t ... Pro110.exe
