Birthdays not displayed in Calendar
DoctorBrown
Been thanked: 7 times
Post by DoctorBrown »
I was cleaning up my database removing duplicate entries in the Agenda display. While doing this, I was changing display parameters, sort field, display dates, and view categories. Then I noticed that the Birthdays were not displayed in any setting. So I went back to the Month display and the birthdays still were not displayed. But if I select a day of a birthday I see the notification in the bottom status bar.
How do I get the birthdays to display correctly?
I have closed and re-opened the app. I've unchecked and rechecked the box in the pane to the right of the left navigation pane.
Essential PIM Pro 11.0.4
Windows 10 system
Android mobile (latest release)
Has thanked: 1616 times
Been thanked: 1133 times
Re: Birthdays not displayed in Calendar
Check if the Birthday field in contacts (use the Edit Fields button from the toolbar) is set to be displayed as appointments in calendar.
CraigS26
Has thanked: 19 times
Been thanked: 28 times
Post by CraigS26 »
Is HERE is where you're speaking of ? ..... Via Hi-light Contact with Birthday/ Rt Clk it/ EDIT / EDIT FIELDS / BIRTHDAY/ EDIT FIELD ...Show as Appt Using Category/ Drop-Dn Arrow/ BIRTHDAY (No Category is Default) .... AND -- BOX Below CHK'd .. Show in Today AND at Bottom of CALENDAR .
PLS Clarify for OP and me any Error per this Pic ....
EPIM PRO LIFE - v12.2 - Win 10 Pro - 22H2 --- ESET EIS Prem - Mbam Prem - Diskeeper Pro '15 - Macrium Pd vX
Yes, that's the way. Although, you can select any contact, it doesn't need to be with birthday.
DoctorBrown
I was not clear enough... Up until a few days ago, the birthday events were displayed in the days of the calendar, and in the notification bar at the bottom. Now the birthday events, do not display in the days of the calendar in month or Agenda views (or any of the options). Here is a screenshot showing this:
Main calendar window.
Screenshot 2022-09-19 095436.png (9.19 KiB) Viewed 840 times
DoctorBrown
i figured it out. In the View > Show Categories, I had deselected the 'None' category.
bobmac1547
Been thanked: 12 times
Post by bobmac1547 »
I've read all through the forums but cannot find a solution...
A very few (maybe 5%) of the birthdays that are in contacts show up in the calendar. I want them all to show up.
The birthday category is the default category for the birthday field.
The birthday category is selected to display in the calendar. (That's how I can see some of them.)
Why would only some appear. What am I doing wrong?????
TIA...
What happens if you create a new test contact and then check the calendar, will the contacts' birthday appear there?
bobmac1547
I created the new test contact and the birthday appeared immediately!
So the issue is how can I get existing contacts' birthdays to appear. I will admit that they were there a long time ago, but between system crashes, new OS, and general insanity, I lost them all but a very few.
Thanks...
What happens if you copy and paste these contacts? Will the birthdays show up for the newly created copies? If they do, you could keep the working copies and delete the originals that aren't functioning properly.
bobmac1547
Yes, copy and paste works. But that's a lot of contacts, and then I have to individually edit out "Copy 1" from each one.
But, knowing that this works, is there another way to get these birthdays back in my calendar without having to copy/paste each one?
Once you have the working copies of the contacts, use the Replace tab in Advanced Search (Ctrl+Shift+F) to remove the "Copy 1" suffix.
bobmac1547
I think it worked! THanks for sticking with me to solve this.
But can't there be an easier way to "refresh" birthdays to the calendar?
This isn't a common type of operation and there are several possible ways to resolve it. Glad to know the one suggested above worked.
