Outlook and Epim pro sync
AdrianHamling
Post by AdrianHamling »
Can you advise if it is possible to sync more than one calendar at a time between Outlook and Epim. Currently appears to only be a drop down allowing one calendar at a time and I need my personal calendar and family calendars to update frequently and without my having to go into the sync box every 10 mins.
Has thanked: 1639 times
Been thanked: 1160 times
Re: Outlook and Epim pro sync
Sure it is. Just click on File->Synchronization->Add Synchronization and then choose either Outlook.com or Office 365 option, whichever is needed. Thanks.
