How to get rid of popup?
I have PIM free 10.1.2.
I don't use the PIM e-mail, only the calendar.
However, I keep getting the Send/Receive e-mail popup.
Is there any way to get rid of it permanently so it won't keep coming?
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: How to get rid of popup?
Maybe you added an email account some time ago which isn't working anymore? If you so, can to go the Mail module, click on Tools->Account Settings and delete the account you don't need anymore or simply go to the account settings, switch to the Advanced tab and disable checking up for new mail. Hope it helps.
