[SOLVED] Open email in new window with keyboard (in vertical layout)
- Has thanked: 17 times
- Been thanked: 10 times
Sorry, if there is already an option for that (I did't find it):
Current situation: If I want to open an email in a separate window, I need always to double-click (mouse) on the email subject/title row. If I use the context window with keyboard (SHIFT+F10) and select "Öffnen" (open) and press Enter-key the email is already open in layout "Vertikale Ansicht". Nothing happens. Also the context menu does not offer an option like "Open in new window".
Suggestion: Implement an additional context option to open the email in an "new window", or trigger "Öffnen" to open always in an new window in vertical layout.
Keep up the good work!
Re: Open email in new window with keyboard (in vertical layout)
Pressing the Enter key will open the selected email in a separate window. Is that what you were looking for? Thanks!
Yes. I was. I found the problem: I had to switch back to Classiv View and then back to Vertical View. Now the Enter key works again. Strange. Thanks for your time. Solved.Pressing the Enter key will open the selected email in a separate window. Is that what you were looking for? Thanks!
Sorry for posting in Suggestions. I thought it was a feature missing in Vertical View.
