Read-only calendars can't be modified
dudu
Been thanked: 4 times
Post by dudu »
Good Night!
When I try syncrhonization by outlook.com come the respost: "Your request can't be completed. Read-only calendars can't be modified".
For this instance I have optated for google account with sucess, but I don't understand what the reason for the fail when choose the outlook.com
Any sugestion?
Grate.
Dudu.
Has thanked: 1616 times
Been thanked: 1133 times
Re: Read-only calendars can't be modified
To provide more information, we'd need to review the synchronization log file, please forward one to us. You can obtain this file by following these steps: Go to Tools -> Options, select "Logs Folder", and locate the file that starts with "OutlookComSync". Thank you!
dudu
Post by dudu »
I use the EssentialPIM Pro 11.7.3 version. When I click on Tools there are the following icons:
Advanced Search/Identifier Explorer/Attachment Manager/Send Newsletters/Print Names/Print Envelopes/Password Creator/PGP Setup Wizard/Manage PGP Key/Configure/Language. But I can't find the icon for Options.
Please see the screenshot below.
dudu
Post by dudu »
I am attaching the file as agreed.
OutlookComSync_2023_11_20_08_05_06.zip
(5.37 KiB) Downloaded 180 times
Great, we've received the log. Thank you for providing it. I will keep you updated on the progress and let you know if we require any additional information.
dudu
Post by dudu »
Aware and grateful. I've used this same synchronization without any trouble in the past. I'll be waiting.
According to the log file, the issue pertains to the event named "BLOQUEADO," which should be saved in the read-only calendar. However, in EPIM, it is not possible to create events directly in read-only calendars. Can you remember any alternative method or workaround that might have allowed for this to be achieved?
dudu
Post by dudu »
Dear Administrator.
Initially thanks for the help but I can't understand the question.
As I'm using Google account synchronization I prefer to keep this other useful method.
Hugs.
Dudu.
In one of the read-only Outlook calendars in EPIM, there is an event labeled "BLOQUEADO". Could you please provide more information about its origin or source? Thank you.
dudu
Post by dudu »
I need frenquentely dedicate on another job and how I can't work in two locations simultaneous when I insert the expression "BLOQUEADO" that in brazilian portuguese means Blocked. In abstract rather than insert a name of a eventualy cliente I fill the expression "BLOQUEADO" how I had proceeded for long years without impedition.
Eventual client other Bloqueado.pdf
(99.24 KiB) Downloaded 185 times
Which calendar do these events belong to, and which account does that calendar belong to?
dudu
Post by dudu »
I don't know how to answer both questions Given the above, I'm giving up on a possible resolution to my problem No more for now Thank you in advance
dudu
Post by dudu »
Dear Admin:
Good morning!
"Synchronization" was "successful" after updating to current version 11.8.1
Yours sincerely.
Dudu.
