Kanban Query
XineBBSA
Has thanked: 8 times
Been thanked: 7 times
Kanban Query
Post by XineBBSA »
I usually use tasks as, er, tasks - but I'd like to see them as Kanban items.
The problem I have is that I have this structure
TOP-THINGY
--Task
--Task
Or
TOP-THINGY
--1ST-THINGY
----Task
----Task
--2ND-THINGY
----Task
----Task
----Task
I can't really use Kanban as it displays all the TOP-THINGY and the 1ST-THINGY/2ND-THINGY things as 'To do' - is there a way I can either
1. Create a swim lane for each THINGY
AND/OR
2. Mark the THINGY as not to be displayed on Kanban (But maybe view that THINGY as an Epic)
I haven't found a way I can do it. Probably the easiest thing to do to implement until Kanban properly set up would be to have a tick box with 'Display on Kanban?' - that way you can just see your items, but the Swimlane would be fantastic too
Xine
Has thanked: 1616 times
Been thanked: 1134 times
Re: Kanban Query
None of the suggested features are currently available in EPIM. We will assess the demand from our users, and if there is significant interest, we will prioritize working on implementing them. Thank you.
