Blank messages
mikebravo
Blank messages
Post by mikebravo »
I am starting to get a lot of messages that are just blank in the preview pane but I can read them if I open the message or reply to it and I am wondering if it started with the 12.0.5 update and wondered if anyone might have same thing going on.
CraigS26
Has thanked: 19 times
Been thanked: 28 times
Re: Blank messages
Post by CraigS26 »
You're describing what 12.0.5 FIXED for ME ref PREVIEW.
Until 0.5 I had to Re-name (and YOU should TRY this) - (EPIM Pro in Program Files x86) WebView2Loader.dll - TO WebView2Loader.dll.OLD - and THEN Preview worked. --- 0.5 For ME does NOT require .old anymore.....
It may help Admin IF you report what happens when YOU try this Re-Naming.
IF No Chg, just Re-Name Back to .dll ....
EPIM PRO LIFE - v12.2 - Win 10 Pro - 22H2 --- ESET EIS Prem - Mbam Prem - Diskeeper Pro '15 - Macrium Pd vX
Has thanked: 1616 times
Been thanked: 1133 times
Re: Blank messages
Download and install the following build, please: https://www.essentialpim.com/download/t ... 0_new4.exe
Will it start working as expected?
mikebravo
Re: Blank messages
Post by mikebravo »
I tried the webview fix first and it worked but the download also appears to be working OK, so will see how it goes, thanks.
Allekz
Has thanked: 8 times
Been thanked: 17 times
Re: Blank messages
Post by Allekz »
admin wrote: Tue Aug 06, 2024 8:20 am Download and install the following build, please: https://www.essentialpim.com/download/t ... 0_new4.exe
It worked for me.
huntrashmi
Re: Blank messages
Post by huntrashmi »
mikebravo wrote: Thu Aug 08, 2024 6:38 pm I tried the webview fix first and it worked but the download also appears to be working OK, so will see how it goes, thanks.
Have you fixed that error? I have the same problem.
CraigS26
Re: Blank messages
Post by CraigS26 »
huntrashmi wrote: Wed Aug 14, 2024 6:04 am
Your question makes no mention of WHAT 12.0.5 version you 're speaking of.
The Link from - admin - a few posts above ending - new4.exe - WAS MY Solution and apparently MikeBravo's.
If not installed, then Try It. - IF you installed new4 then confirm That.
aurio
Been thanked: 12 times
Re: Blank messages
Post by aurio »
not directly related to the problem but again we need build versioning 8)
EPIM Pro 11.8.4 Business Edition - 3 Users - Network
Language: German/English
CraigS26
Re: Blank messages
Post by CraigS26 »
aurio wrote: Fri Aug 16, 2024 10:15 am not directly related to the problem but again we need build versioning 8)
We're on 12.0.5 and there have been 4 modifications to it attempting to fix reported issues.
These 4 have been offered in admin posts with the Links names (to install and try) ending (ie) -- new2.exe, new3.exe, and Most Recent - new4.exe - currently 5 posts above your's (Aug 6 2:20am)......
As stated, the - new4.exe - Version I installed from This Thread Fixed mine.
aurio
Re: Blank messages
Post by aurio »
This is certainly correct and, as a quick help within the support thread, it is okay and shows how quickly and flexibly EPIM support and EPIM developers can respond to bugs, much faster than most other software developers.
But right here you can see that the build versioning that has been suggested many times would be helpful. For example, it is not clear whether the "new4.exe" can only be downloaded here, or in another thread or how it differs from the official download version or not.
