Tiny widget text
Tiny widget text
Why is the text so tiny on the monthly calendar widget?? It is tinier even than the size of the calendar within the app itself! Is it compressed, or what? I cannot even use it because the text is so tiny and illegible.
Consider using a more narrow font, BUT at a larger size, in order to show MORE TEXT in the same space, and more LEGIBLE dates in general.
I will attach a screenshot of the XXX Calendar widget, just to give you some ideas.
I'm using a Galaxy A54 5G w Android 14, AND separately I'm also using a Galaxy S10+ SM-G975U1 with Android 12.0 w system-wide dark theme and a system-wide dark theme.
Re: Tiny widget text
Could you please forward us a screenshot of how it looks on your end? This will help us gain a better understanding.
Here is the current EPIM widget using the dark theme with the background at 100% transparency
What device was the screenshot taken from? What are the system font settings on that device?
