View of Groups
michaelarch
View of Groups
Post by michaelarch »
Is there a view (or the ability to create a view) that shows ALL groups on one screen along with all of the fields (including added fields) associated with each group? I would hope to sort Groups using the various fields available.
I want to use Groups to divide all entries (contacts, notes, calendar events, etc) into projects.
Has thanked: 1616 times
Been thanked: 1134 times
Re: View of Groups
Which modules are you referring to? For all of them? If so, clicking the root folder usually displays all items within the grouped folders below it.
