Customized Activating Monthly Calendars in EPIMtoday left sidebar
AJ
Has thanked: 50 times
Been thanked: 8 times
Post by AJ »
hi admin,
to do most things out of epimtoday i would appriciate to add or activate the monthly calendars in the left sidebar of epimtoday.
by that i got a efficiency idea, will write more few lines later.
you could quick, direct add new appointments or tasks of the next three months!
you could direcly add holidays, maybe with new feature...
no idea if allready possible to add longer appointments like holidays by marking first and last day by pushed shift, alt or control.
i fogot the trick for selecting in windows.
thx
ps: i would let the left sidebar expanded for that, but use the other functions in top menu.
hope i can put the left side menubar / modul buttons on top middle, next to top menu.
Helps Make EPIM Great/No1!
